Home › Forums › Products › Stompboxes › H90 Midi Global Settings › Reply To: H90 Midi Global Settings
I have a use case where I’d like to switch between global routing modes ideally using midi on a guitar rig for live performance.
I use a pedalboard with analog drive pedals, digital effects and a midi loop switcher with one of the loops connected to input/output-3 on the h90 and the final loop switcher output connected to input-1 of the h90. Outputs 3&4 of the h90 go to a micro line mixer where i combine the dry (normally analog – no AD-DA conversion) guitar sound from the pedal board with the h90 (and other effect processor) outputs for a studio -style effect send-return setup.
As an example – If I need to add a gate to suppress noise from distortion/overdrive pedals on the dry guitar sound I can use the Omnipressor in the Dynaverb algorithm (very nice by the way!) by switching in the loop connecting to the h90, so that i don’t need an extra analog pedal as a gate. But to do this I need to switch to the Dual global routing mode on the H90. Normally I would be using Insert global mode so I can use the 2 effects blocks in series or parallel after the loop switcher, but sometimes switching between clean and heavily overdriven sounds switching to that Dual mode and back again using midi would be useful..
Also wondering if the Eventide design team is thinking of adding more dynamics processing algorithms to the H90? – EQs, comps, gates, etc. A ‘Multi’ effect channel strip would be nice too.
Thanks,
Martin
