Home Forums Products Stompboxes H90 Routing Questions Reply To: H90 Routing Questions
#187979
Craig Shuard
    Hi there,
    I have a related question about balance between algorithms in series with global kill dry on. If I’m using delay going into a reverb I want the delay signal to only have a small amount of reverb on it to push the delay back in the mix. If I adjust the wet mix to 100 on the delay algo it turns up the delay into the reverb at full wet. If I adjust to zero it kills the whole signal. If I adjust the wet mix on the reverb algo to zero, again it kills the whole signal, if I adjust ot to 100 it just turns up the fully wet reverb.
    There is no way to adjust the balance of the amount of delayed signal being effected by the reverb- this seems like a pretty standard adjustment for 2 effects in series.  Am I missing something?
    Cheers!
