Home Forums Products Stompboxes Instrument and line level settings for insert effects Reply To: Instrument and line level settings for insert effects
#189285
thebukman
    Thanks but I am still a bit unclear.
    Could you perhaps explain what the line and instrument setting actually does?
    I know I could manually adjust the levels of 1/2 and 3 and 4 but why do you also have the instrument and line level setting available?
    Eg what does changing output 3 and 4 from line to instrument level actually do to the signal? Does it apply any standard reduction in the send level going to my reverb pedal?
    Same with setting the return to 3 and 4 to line level. Will it apply any increase to the signal coming from my reverb pedal?
