Home › Forums › Products › Rackmount › Is this possible (and if not, it ought to be) › Reply To: Is this possible (and if not, it ought to be)
Thanks for your post. Favorites are not currently available on the H9000/Emote, but we’re working on this for a future update. I’m sorry, but what you are requesting for auto-routing via a plug-in is very complicated and not something that we are currently considering.
As far as using the H9000 to replace plug-ins, with a little bit of effort your can create a DAW template that has all of your ADAT and analog send/return channels setup for the H9000 automatically. For example, my Ableton Live default template has 4 effects busses, 1 for each FX Chain. These busses are automatically routed to the H9000, because I’ve configured them to be that way in the DAW template. I simply need to load up an H9000 session that matches this routing, and everything is setup. You can create a few different H9000 session templates for the algorithms/FX Chains that you use more frequently. If you save that Session with Emote loaded as a plug-in, then you can recall of the same settings the next time you load the DAW project.
Let me know if that is useful.
