Home Forums Products Rackmount Eclipse silent preset Reply To: Eclipse silent preset
#189489
woupida
    That was a good idea to advise me to check routings.
    First it only happens when routings is on “series”. That’s how I discovered that some program are suspect. When I set the preset to parallels i have an effect. Or when I switch the suspect block off, the preset works “on one leg”, with only a block.
    I didn’t check all the presets but some of the bad block can be identified, like m_chorusdelays
    The “only” difference between my two Eclipse is the version of the OS (“powering on 4.04”).
    Would it be possible to downgrade the OS of the Eclipse. Is it worht it ?
