Home › Forums › Products › Stompboxes › H90 Looper REC / PLAYBACK Speed › Reply To: H90 Looper REC / PLAYBACK Speed
April 18, 2025 at 10:29 am
#189620
I think I see where you’re going with this, but I’m not in front of the Looper to confirm it. So, from memory, something to try out:
- Max Length: 120 Sec / Rec Speed: 1X / Resolution: Smooth
- Bind the full range of Play Speed to HotKnob P as your control source.
- Dial HotKnob P to Play Speed = 100.
A return-to-center control (like Pitch Wheel) would be ideal for this, if that was supported. It might be difficult to hold position at 100 with an EXP pedal & smooth resolution. But it illustrates the option of external control over HotKnob P, which in turn will control the Play Speed.
