Home Forums Products Stompboxes Knifedrop AUX Switch Capabilities? Reply To: Knifedrop AUX Switch Capabilities?
#190055
    Ok, some further troubleshooting steps you can take:
    Are you sure you’ve connected the correct output from the OXU to the exp pedal input on the Knife Drop?
    Do you have another pedal you can try using the OXU with?
    Do you have another aux switch or expression pedal you can try connecting to the Knife Drop?
