Home Forums Products Stompboxes ? Simple “Effects Loop” Setup? Reply To: ? Simple “Effects Loop” Setup?
#190429
thejohnsupremo
    Can you use the H90 as said above and place another pedal, for me it is a graphic EQ I love, into the H90 input/output so it is also included in the amps loop since I want it at the end of the signal chain? I tried putting the pedal out to the H90 in #2 and H90 out #2 to the pedal Input but nothing happened.
