Home Forums Products Stompboxes ? Simple “Effects Loop” Setup? Reply To: ? Simple “Effects Loop” Setup?
#190438
    Yes, there are a few options: If you always want the EQ pedal at the end of the chain:
    1. Connect guitar directly to amp
    2. Connect Amp Send to H90 input 1
    3. Connect H90 output 1 to EQ pedal input
    4. Connect Amp Return to EQ pedal output
    You could also use the EQ pedal in the insert path of the H90, this will allow you to place the EQ at different parts of the signal chains (before/after/between the H90 presets.)
    3. Connect Amp Return to H90 output 1
    4. Connect H90 output 3 to EQ pedal input
    5. Connect H90 input 3 to EQ pedal output
    6. Press the routing button to enter the Routing menu and choose where the EQ should go.
    7. More info about using inserts can be found here: https://cdn.eventideaudio.com/manuals/h90/1.10.7/content/edit-modes/routing.html#insert-routing
