Home Forums Products Plug-Ins Temperance Lite 1.0.1 reported to be incompatible with Logic Pro Reply To: Temperance Lite 1.0.1 reported to be incompatible with Logic Pro
#192566
    Please try the steps below and let me know what happens:
    1. Close Logic Pro X
    2. Make sure Finder is the active application
    3. While holding the Option key, click on the Go menu at the top of your screen and select Library
    4. Delete the following files from your User Library, if they are present:
      • ~/Library/Caches/com.apple.audiounits.cache
      • ~/Library/Caches/AudioUnitCache/
      • ~/Library/Preferences/com.apple.audio.InfoHelper.plist
      • ~/Library/Preferences/com.apple.audio.SandboxHelper.plist
    5. Then, open a Terminal window (located at Applications/Utilities/Terminal), and enter the following commands (type each command and press “Enter” afterwards):
      • killall -9 cfprefsd
      • killall -9 AudioComponentRegistrar
    6. Restart your computer
    7. Restart Logic Pro X
