Home Forums Products Stompboxes No audio output when switching from bypass to active. Reply To: No audio output when switching from bypass to active.
#192693
calaverasgrande
    Well I switched kill dry to off, and changed bypass mode and somehwere along the line it started working.
    This happens at least once a month and it’s always ‘wave a chicken over it until something works’. There doesn’t seem to be a clear cut way to get it working again.
    LOGICALLY I want kill dry ON because it’s a send effect and dry signal affects level balance. I’d also prefer relay bypass if I have to have it, but I’d rather no bypass is possible. Since it’s a send effect.
    It kind of boggles the mind that I would get zero signal with kill dry enabled?
