Home Forums Products Stompboxes wet/dry – simplified Reply To: wet/dry – simplified
#193023
    Within a given Program on the H90, there can be many ways to adjust the wet/dry mix.
    • The Program has an overall Mix knob
    • The Program consists of 2 presets (2 “effects” to simplify the terms). Each preset also has a mix or effect level knob.
    If you use the H90 Control app, its easier to get a top-down view of all the parameters and figure out which you may want to adjust. If you don’t want to use the control app, you can press the “Parameters” button to cycle through the various parameters and adjust the mix/intensity values.
    The “Floating In Space” Program is two instances of Blackhole, so it’s gonna be a pretty extreme reverb/pad sound. Adjusting the Program mix would be your best bet for this one.
    I’d suggest going through the user manual or watching some of our tutorials to get a better idea of how the pedal works: https://www.eventideaudio.com/forums/topic/h90-video-tutorials/
