Home Forums Products Rackmount Are These H90 Presets Available in the H9000? Reply To: Are These H90 Presets Available in the H9000?
#193134
    Hi Ed,
    These Programs aren’t available in the H9000 as FX Chains. We may be able to have them ported in a future release.
    You can see in H90 UI which algorithms are being used:
    Stargazers = Crystals + Shimmer
    Entanglements = UltraTap + Tremoloverb
    PrismVibe = PrismShift + Even-Vibe
    etc.
    The H9000 is capable of endless sounds that are similar to this by just experimenting with different algorithm combinations, that is part of the fun of using it. You can combine more effects in an FX chain than you can in an H90 Program so there is much more that you can achieve on the H90.
    I’d suggest experimenting with various combinations of the algorithms listed above and I’m sure you’ll come up with some very interesting results with little effort.
