Home Forums Products Stompboxes Routing configuration recommendation Reply To: Routing configuration recommendation
#194399
joecozzi
    There is no correct answer to this. The best answer depends on where you require the necessary tone shaping to get things sounding like you want. Nevertheless, the advantage of using the H90’s insert is that you can move the EQ”s position on a program basis; for one Program the EQ could appear before the Eventide effect signal chain, for another in between, or at the end.
