Home Forums Products Plug-Ins How to improve the Physion latency (2832 samples!) Reply To: How to improve the Physion latency (2832 samples!)
#149867
cauldron
    Hi Tom,
    I apologize. I have redoed the measurements and I confirm what you said except for 176.4kHz and 192kHz which are 10512 samples.
    I used a buffer of 8192 samples. The round-trip time is measured (with and without the Physion plugin) using the jack_delay utility ( https://kokkinizita.linuxaudio.org/linuxaudio/downloads/jack_delay-0.4.0.tar.bz2 ). Jack Audio includes the jack_iodelay utility which is equivalent.
    Latency is always constant (just over 50ms).
    192kHz  ***10512***
          26896.000 frames  140.083 ms
          16384.000 frames   85.333 ms
    176.4kHz ***10512***
          26896.000 frames  152.472 ms
          16384.000 frames   92.880 ms
    96kHz ***5392***
          21776.000 frames  226.833 ms
          16384.000 frames  170.667 ms
    88.2kHz ***5392***
          21776.000 frames  246.893 ms
          16384.000 frames  185.760 ms
    48kHz  ***2832***
          19216.000 frames  400.333 ms
          16384.000 frames  341.333 ms
    44.1kHz ***2832***
          19216.000 frames  435.737 ms
          16384.000 frames  371.519 ms
    Elia
