Home Forums Products Stompboxes PitchFactor Preset Programming: “Other” Effects Reply To: PitchFactor Preset Programming: “Other” Effects
#135197
    EdgeDelays
    Mix = WET:50
    Pitch Mix = A10+B10
    Pitch A = 1:000
    Pitch B = 1.000
    Delay A = 1/4
    Delay B = 1/8*
    (encoder) = 910/949 / TMP ON
    Depth / Key = MODERN
    Speed / Scale = CHROMTC
    Xnob = FBKA: 0
    Ynob = FBKB: 0
    (EXP PED Heel) = FBKA: 0  FBKB: 0
    (EXP PED Toe) = FBKA: 100  FBKB: 100
    The PitchFactor functions as a great primary or secondary digital delay unit.  This preset exploits the dotted eighth rhythmic effects.  By changing Depth / Key to one of the H910 or H949 variations, it's possible to emulate one of the earlier bucket-brigade digital delays.
    Expression Pedal:
    Not all delay units will allow infinite feedback.  Although this preset can go into short-delay looper territory, the expression pedal is set up for active use here.  The heel position snaps back to one repeat from each delay line.  The toe position goes into total regeneration.  By moving the pedal to many intermediate positions, the short delays are perceived as additional notes played, or rapid arpeggios & finger-picking.
