Home Forums Products Stompboxes Replacing the MIDI Connectors on all the Factor Pedals Reply To: Replacing the MIDI Connectors on all the Factor Pedals
#146263
camn
    Actually- I did a little research–and this is totally what should happen.
    Its from this post:
    What if we used stereo minijack cables for MIDI?
    It turns out that although MIDI uses a 5-pin connector- it doesnt UTILIZE all 5. Only 3. So do this:
    Put that jack on your Factor pedals and start using 1/8″ jacks. They make THOSE in right angle!
    And for your USB midi gear- this thing: http://www.hobbytronics.co.uk/usb-host-board-v2
    will certainly wire up to an 1/8″ jack just fine.
