Home › Forums › Products › Stompboxes › Can’t load location L13 on H9 device › Reply To: Can’t load location L13 on H9 device
February 13, 2019 at 7:58 pm
#151287
I did the reset. With the init presets loaded and read back to Control, position L13 shows in Control as loaded with the Ballerina preset. Then, I resent my live preset list to the pedal, and when I read the pedal back to Control, L13 was once again empty in the Control display. I went a step further and cycled through the presets from the pedal itself using the tap button. When I get to L13 on the pedal, the expected preset is there! The name is correct and the preset is what I programmed. But the L13 in Control is empty. Bizarre.
