Reply To: Sustain pedal
Home Forums Products Stompboxes Sustain pedal Reply To: Sustain pedal
#151838
Dario
“….Good news is that a single external switch (like a physical sustain pedal) defaults to BYPASS control…”
ok, I can use my Boss FS-5U footswitch, but I will have
1) again to double-tap to achieve the BYPASS
2) use the same with two switches : the Boss FS-5U and the SuperEgo+ Bypass switch.
I don’t know if it will be handy…
anyway, I’d use a lower Decay setting to get it to cleanly shut down the sustained notes,
it could be a solution
