Home Forums Products Eurorack Modules Power for Misha in MIDI mode Reply To: Power for Misha in MIDI mode
#165793
    Misha uses a standard Eurorack power supply, so the -12V rail is necessary. If you are building a custom case, you would also need to look into adding a Eurorack power supply to your case. The 4MS option is your best bet and is a good price considering it comes with the necessary power supply.
