Reply To: Saving a Preset & Reverb Freeze option
Home Forums Products Stompboxes Saving a Preset & Reverb Freeze option Reply To: Saving a Preset & Reverb Freeze option
#169160
logicbdj
Sorry, it’s not quite clear what is happening. The Factory Programs/Presets cannot be overwritten. If you save a different Program over User 1 > Program 1, you are not erasing that Program, you are saving a new Program to that slot. You can always find the Factory Programs by browsing the Program Library, select the Factory 1 List, and you can find that first Program there. By default, the User 2 list is full of INIT (blank) Programs. If you select a Program slot and import two presets, then save the Program, you should now be able to reload that exact Program. There are no original Presets/Programs on the User 2 list, they are all blank Program slots. The Freeze parameters of a Reverb are not Performance Parameters that can be assigned to a footswitch, you must adjust the Reverb’s decay knob to access the Freeze or Infinite settings. You can map the Decay knob to a HotSwitch, and then assign the HotSwitch to a footswitch to accomplish the same thing. SP2016 Reverb does not have a freeze or infinite decay parameter, but all of the Space reverbs do. Let me know if you have any other questions.
Why is it that I altered the SP2016 clean ambient… saved it (with a different delay), but now my clean ambient under Factory is no longer there to choose? I even did a Factory Reset and it’s no longer there. But I can find my altered version in the User 1 set?
