Home Forums Products Plug-Ins Anthology II and Digidesign Venue Reply To: Anthology II and Digidesign Venue
#116721
Posted by Jeff
Hi Dan, All,
I am a product specialist with Digidesign for Live Sound. If you are wanting to use this file with your DShow system, you need to place it in this directory. (The file structure is incorrect on the previous post.)
D:User Data/D-Show/User Data/Effect Presets/Factory Presets/Factory/
If you download this file with a Mac, simply drag it onto a usb drive, plug into D-Show, Open the file with notepad. Save as 975-231 MICROPITCHSHIFT.tfx into the correct file structure listed above. (The file will think it is a text and will not work if you do not take the .txt off the end of the file.)
Hope this helps. Take care. JP
