Home › Forums › Products › Stompboxes › TimeFactor–Bypass not accurate? › Reply To: TimeFactor–Bypass not accurate?
#116935
DGillespie
    Hi rlab777,
    My guess would be that you Dual Rectifier has parallel effects loop and you have Time Factors Kill Dry option off.
    If that is the case, turn Kill Dry on in the system menu under bypass choices and it should clear your problem right up.
