Home › Forums › Products › Stompboxes › Tap Tempo Issue › Reply To: Tap Tempo Issue
#116948
achaput
     Hi John,
    The way to do something like this would be to turn Tempo ON. This is done by pressing the Encoder button once. Then you can set the delays to different rhythmic note values, such as a dotted eighth note and a quarter note, and when you tap tempo, the relationship between the two delays will remain.
    Alan
