Home Forums Products Stompboxes Can you control TimeFactor from ModFactor or Vice Versa? Reply To: Can you control TimeFactor from ModFactor or Vice Versa?
#117069
     You could actually just connect one pedal to both units with a Y-cord.
    The pedal input is protected enough that this won't damage the units.
    There is a slight risk of ground loops, but if the units are going to be connected together anyhow this should not be an issue.
     Note – I have not tried this …
