Home › Forums › Products › Stompboxes › Boss expression pedals › Reply To: Boss expression pedals
        March 26, 2008 at 11:51 pm
        #117238
There's no sound passing through the pedal when using it as an expression pedal, so it doesn't matter whether you use the L or H model. If you want to use it as a regular volume pedal in front of a guitar amp you should probably go for the H model.
