Home › Forums › Products › Stompboxes › MIDI –> Timefactor –> Issue after V2.0.2b4 › Reply To: MIDI –> Timefactor –> Issue after V2.0.2b4
April 7, 2008 at 4:12 pm
#117324
Hi Michael,
I have tested this on my TimeFactor and found it to be working correctly. Have you looked at the RCV MAP menu under MIDI in System Mode? I wonder if the Presets higher than 10:2 are not assigned in your receieve map. Can you verifiy this?
Alan
