Home › Forums › Products › Rackmount › SP/DIF questions › Reply To: SP/DIF questions
#117471
ThreeFingersOfLove
    Hi Italo,
    I know about the SP/DIF being a consumer digital protocol. I just wanted to clarify between "doesn't recommend because problems may appear" and "it won't work at all".
    Also, I think I have read someplace that there is something called SRC. Is this used to change the sample rate prior to hitting the DSPs?
    In the manual, it is also mentioned AES11-AES18. Are these the 8 AES/EBU signals coming from the DB-25 connectors?
    Is there a way to output a signal from analog outs 1, 2 or 3, 4 without it appearing at the AES/EBU outputs? From the manual, I figured that the analog outputs and SP/DIF outputs derive their signal from the AES/EBU. I was just wondering whether there is a workaround, maybe a custom routing?
    Why don't you make available the Routing application to all people so we can see some possible configurations? I have the Routing app for the H-8000 and Orville, but they differ from the H-8000 FW.
    Thanks,
    Yannis.
