Home › Forums › Products › Stompboxes › pedalboard order question: before or after Distortion. › Reply To: pedalboard order question: before or after Distortion.
May 12, 2008 at 4:08 pm
#117483
I think it's very rare that you'd ever want to put your delays before your OD's. Beacause you only want your delays to overdrive once, and not go through the overdrive again and again every time it delays, it's the most common setup to have your delays after your OD's. This is where an FX loop on a tube amp comes in handy. When you put your delay in your amp's FX loop, you can even put your delay in the chain past your preamp overdrive.
