Home › Forums › Products › Stompboxes › Power supply › Reply To: Power supply
#117817
NicD
    As far as I know the Pedal Power Versa isn't available yet :-/
    noisethrills:
    I've been using the voodoo lab pedal power 2 to power the Time factor for several months now with no problem.
    Which outputs on the PP2 are  you using ? Everything working normally ?
    Also, a guy on the HRI board says he's powering his TF and MF with a T Rex Juicy Lucy, using the doubler to provide the pedals with 600mA@12VDC. Here's the thread: http://www.hugeracksinc.com/forum/viewtopic.php?t=47755
     Looks pretty nice, but I wonder if there may be any problem with powering my TF with 12 VDC, while the tech specs and the wallwart say 9VDC.
    Anyone from the Eventide staff care to confirm wether it's fine th use that ? If it's 100% safe, I'll gladly ditch the wallwart (it's currently secured below my Pedaltrain, but I'd prefer a "cleaner" solution), but I'd rather have your opinion on it first.
    Thanks in advance.
    Nic
