Home › Forums › Products › Rackmount › H8000 FW QUESTIONS › Reply To: H8000 FW QUESTIONS
#118549
 Hi
the H8000FW can be used as an audio interface. Different kinds of limitations may exist, depending on the used DAW software.
The unit has 174 seconds for mono sampling time @48KHz sampling rate, in addition to many other seconds for delay. The sampling memory can also be used as delay memory, depending on which module is used in a preset. Most delay presets though do not use sampling memory.
best
I
