Home › Forums › Products › Stompboxes › Timefactor Signal Routing › Reply To: Timefactor Signal Routing
May 6, 2009 at 4:31 pm
#118573
You could do that by using a mixer. Connect the TF in the mixer's effects send/return and set to Killdry ON. Connect the guitar to one of the mixer's inputs and then you can mix the dry guitar with the 100% wet signal from the TF.
