Home › Forums › Products › Stompboxes › Pitchfactor latency issue › Reply To: Pitchfactor latency issue
#118891
wedelich
    Hi Buttcheex8,
    You should try setting the PF source to "Synth Lead."  You can do this by entering the system mode, then going into the Utilities menu.  In Utilities select Source, then scroll over until you see "Synth Lead."  Once it's set, you can exit system mode.
    Telling the PF to assume this type of soure will make it track faster at the expense of some polyphonic ability and low note recognition.  We made sure to include different pitchshifing source modes to cover the wide range of uses we could forsee.
    Here is a link to a thread where I discussed this with a user back in April, and it may have some information that you could use as well.  Let me know if any of this helps.
    http://forum.eventide.com/cs/forums/p/5423/23020.aspx#23020
