Home › Forums › Products › Stompboxes › pitchfactor on saxophones…. › Reply To: pitchfactor on saxophones….
        August 17, 2009 at 8:24 am
        #118928
Hi jongwonl
consider that in addition to correct settings for the pitch shidter, you'll also need to keep the mic signal preamplified to correctly work with the Pitch Factor, as with the 4000. The pedal will work with line level signals and a preamped signal is what it expects to see.
kind regards
I
