Home Forums Products Stompboxes Chord freeze function Reply To: Chord freeze function
#118978
Thanks for reply! When you play with these settings – does this algorithm work?
1. You play a chord and 'freeze' it with an expression pedal
2. Move a pedal (the sound does not change)
3. Play more notes (a solo, for example) – the effect is not applied to these notes
4. Move pedal again – the chord stops playing
