Home Forums Products Stompboxes Midi Program Change Transmit on Mod/Pitch/TimeFactor Reply To: Midi Program Change Transmit on Mod/Pitch/TimeFactor
#119103
    If you use MIDI program change to load a preset on the MF it does not send a program change. Sorry.
    You will probably have to set up the MF in MIDI thru, and use the Rx MIDImap such that you can send Program Change messages the TC will accept and also load the right presets on the MF.
