Home Forums Products Stompboxes Timfactor Dead???? Need help Reply To: Timfactor Dead???? Need help
#119127
    This sounds like (you know this) the update failed. During the second while all the lights are on, hit the middle switch.
    If it says UPDATE, you are OK, and should try the update again. If you get problems, you should probably try a different computer.
