Home Forums Products Stompboxes How to bypass the PitchFactor using MIDI Reply To: How to bypass the PitchFactor using MIDI
#119261
It really is all in the manual. Look at p.47-48 if you want to use a CC (Continuous Controller), or p.49 if you want to use Program Change.
There's not much I can usefully add without some indication of the problem you are having. Friends can also be helpful.
