Home › Forums › Products › Stompboxes › TimeFactor Lib setup › Reply To: TimeFactor Lib setup
#119385
    Nothing you have to do to the TF except to plug in a USB or MIDI cable.
    This assumes the TF MIDI settings are the defaults.If you are unsure, do a CLEAR SETUP or check that : "SYS ID" = 1,  "OUTPUT" = XMT.
    You may have to configure FactorLib to see your MIDI/USB feed. Wait until it is plugged in, the go to MIDI/config.
