Home Forums Products Stompboxes MF TF OD 100 FX Loop Reply To: MF TF OD 100 FX Loop
#119402
Hi thanks for the quick reply. I changed the serial into a parallel loop and it works perfect. I like the choice of mixing the effect to the dry sound. It sounds just awesome. I think that I'm going with the option of putting the Modfactor in front of the amp and the Timefactor into the effect loop. I think the only weak point is that you can't tab the tempo in bank mode. I don't know if it's  possible or if you already discussed it, but the Tab Tempo could always be  active if, the buttons would be configured in  a different way. The left footswitch could be the up and down switch for the banks (hold the button to get to the previous bank). The middle footswitch could be used to choose the presets. The user could program the bank starting with the first or second preset. So the tap tempo could always be active. Maybe an idea for a future update.
