Home › Forums › Products › Rackmount › Eventide Orville Output Noises › Reply To: Eventide Orville Output Noises
November 16, 2009 at 9:07 am
#119482
IDeangelis
HI Nicolas
you should make sure the Orville is the cause of the noise. Disconnect every other piece of gear and listen to Orville >Speakers only. Keep your levels DOWN!!!!
If Orville is making that noise, you can try resetting the unit, even though this sounds like a mayor problem. Resetting requires powering the unit while holding down the 8 key. THIS WILL ERASE ALL YOUR PRESETS!!! So back them up first.
If the problem is still there, you should contact our german distributor Sound Service in Berlin or support@eventide.com for servicing the unit.
good LUCK!
i
