Home Forums Products Stompboxes Pitchfactor: can’t get past bank 13:2 Reply To: Pitchfactor: can’t get past bank 13:2
#119545
jhyman
    You need to go into System Mode by pressing and holding down the Encoder and Right Footswitch button together. Then turn the Encoder to UTILITY, select it by pressing it down, turn it to BANKS and select it, and then set the range of the banks you want to use. Yours is probably set to an upper limit of 13.
