Home › Forums › Products › Stompboxes › Using PitchFactor with distortion › Reply To: Using PitchFactor with distortion
November 30, 2009 at 12:44 am
#119578
You probably know that PF should be in your effects loop if you are using distortion in your amp's preamp. It will mess up everything if it's up front before distortion.. would be like feeding a complex chord (several different notes) into distortion: a mess. Just a thought.
