Home Forums Products Vsig and Preset Development Help with C_Counter reset Reply To: Help with C_Counter reset
#119664
sean.e
    By re-ordering the inputs to the C_Merge that is used to drive the
    counter clock input, I'm able to get the auto-reset to work without
    requiring multiple triggers at maxcount.  But it is done at the expense
    of the manual reset trigger.  The manual reset trigger works fine for
    all values except at maxcount – at which point it requires two
    consecutive trigger presses.  Fine trade off compared to the previous
    behavior.
    Here's the current version of the test:
    HEADM adc 2 2 iSwitchL-out iSwitchL-out Empty Empty 1 menupage-obj ;=0,25,100,0
    ISWITCH iSwitchL 4 SelectCounter-out adc-in1 adc-null adc-in1 adc-null ;=575,25,100,0
    C_MERGE resetCounter 2 SelectCounter-timeout reset-out ;=400,175,100,0
    STEXTKNOB
    SelectTextKnob %s select 4 0 SelectCounter-out "textknob: select 0"
    "textknob: select 1" "textknob: select 2" "textknob: select 3"
    ;=575,225,100,0
    C_MERGE incrementCounter 3 resetCounter-out SelectTextKnob-textnum_out increment-out ;=400,325,100,0
    C_COUNTER SelectCounter incrementCounter-out resetCounter-out 1 3 ;=575,350,100,0
    MENUPAGE
    menupage menupage menupage 5 increment-obj SelectTextKnob-obj
    counterMonitor-obj textKnobMonitor-obj reset-obj ;=950,150,100,0
    MONITOR counterMonitor SelectCounter-out "counter:         %1.0f" cntMonitor ;=800,350,100,0
    MONITOR textKnobMonitor SelectTextKnob-textnum_out textknobMon:%2.4f knobMonitor ;=800,225,100,0
    TRIGGER increment increment increment ;=100,575,100,0
    TRIGGER reset reset reset ;=250,575,100,0
    Now
    I'm trying to figure out why incrementing the STEXTKNOB only causes the
    C_Counter to increment once.  If you increment the textknob multiple
    times (using the up arrow key), its monitor (added in the current
    version of the test) shows the expected output of the knob, but the
    counter monitor only updates once – the counter and textknob monitors
    get out of sync.  Not so when using the Trigger instead of the
    STextKnob.
