Reply To: Any way to prevent outgoing CC transmit to through port
Home Forums Products Stompboxes Any way to prevent outgoing CC transmit to through port Reply To: Any way to prevent outgoing CC transmit to through port
#119791
The TF will only pass MIDI inputs to its MIDI outputs when it is configured for MIDI/OUTPUT=THRU. If you select OUTPUT=XMT it should block the inputs.
Interestingly, many of our other users want the inputs to go to the outputs always !!
