Home › Forums › Products › Stompboxes › PITCH FACTOR AND MOMENTARY EXTERNAL SWITCH › Reply To: PITCH FACTOR AND MOMENTARY EXTERNAL SWITCH
January 19, 2010 at 6:53 pm
#119814
You can't do it with a regular switch (this only toggles the bypass state), but you can by using a MIDI controller, which will allow you to control Bypass On (BYP) Bypass Off (ACT) or Bypass Toggle (TOG).
