Home › Forums › Products › Stompboxes › One expression pedal for two units? (on A/B switch) › Reply To: One expression pedal for two units? (on A/B switch)
February 7, 2010 at 9:23 pm
#119949
Hey Russ,
works perfectly. Both units (MF/TF) are controlled now with one Ernie Ball Expression Pedal. How cool is that
. But I'm having a problem with my MIdi Controller (G-minor) now
. Since I had to change the output on the MF from thru to XMT I can't change both units with my controller anymore. The banks and the other stuff I programmed works only with the MF now. Is there another way to make both things (Expression/midi control) work?
My setup is
G-minor out –>MF in
> MF out —> TF in
Would be great if you could help me out.
