Home › Forums › Products › Stompboxes › Problem with reverse on TF › Reply To: Problem with reverse on TF
March 20, 2010 at 3:31 am
#120180
i'm guessing it's cause you have the mix set to 100% wet. add some dry signal and see if you can hear what you play over the loop
