Home › Forums › Products › Stompboxes › MIDI control of PicthFactor switch between preset 1 and 2? › Reply To: MIDI control of PicthFactor switch between preset 1 and 2?
March 30, 2010 at 3:13 pm
#120226
FS1-3 operate the footswitches in the alternate mode – example, if you are in BANK mode, they will operate the footswitches in PLAY mode. And vice-versa.
Normally, the best way to select presets via MIDI is to use MIDI Program Change.
