Home › Forums › Products › Stompboxes › External Control of “Bypass Mode” in Time Factor Pedal… › Reply To: External Control of “Bypass Mode” in Time Factor Pedal…
June 21, 2010 at 11:11 pm
#120525
Too sad to hear that… would be a great function!!!
Other idea. As I understand in BYP+DLY mode the delay will keep sounding after I hit the bypass switch form on to off right? But what if instead of that I switch from preset A to B, and preset B is a Blank (no delay set) preset? Would that do the effect of sudden stop?
I think that could work. Unless the "spill over" function works between presents change too?
Thanks for your help guys!
J
